[Contextcapture] Pair selection maximal distance(loop or sequence)
Is there a custom low-level settings to lower max distance between photos to 1 when using loop or sequence mode? Sometimes even if set that photos are in sequence some photos are mixed creating wrong model. We need to have option very strict setting for sequence. Even the wording "maximal distance photo(s)" suggests that it should allow it to be set for 1 photo and not only more than >2 photos.
A screenshot to better understand the issue. The photos are in sequence but because of forward look of 2 next photos the sequence is broken in middle and photo insertion order wrongly mixed.
