<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>ContextCapture FAILED: failed to init rasteriser</title><link>https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/171597/contextcapture-failed-failed-to-init-rasteriser</link><description>I have successfully produced a 3D mesh and can produce a tiled orthophoto/DSM, but I cannot produce an untiled, continuous orthophoto. It seems that every time I try to produce a figure with a maximum image part dimension greater than 20000 pixels I get</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: ContextCapture FAILED: failed to init rasteriser</title><link>https://communities.bentley.com/thread/494008?ContentTypeID=1</link><pubDate>Wed, 28 Nov 2018 10:33:28 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:6a237ae0-fb39-4bf4-8087-160f22ef85ce</guid><dc:creator>Felix James</dc:creator><description>&lt;p&gt;It is not currently possible to generate a big orthophoto in ContextCapture. There is actually no limit per se, it is mostly dependent on the GPU. We would recommend that you use ContextCapture Editor to &amp;quot;Merge&amp;quot; the images into a single file.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
