Hello, I'm new to ContextCapture. I'm make Mesh model from stereophotos. ı wanna retouching my mesh model with microstation and descartes but ı can't. 'because the program gives ' no element ' and 'only read' error. how do I fix this?rsvp.
When you use the OBJ export format for retouching, you need to first save the OBJ as DGN before retouching it. Otherwise it may be opened read-only.
This video shows the workflow for OBJ export: https://www.youtube.com/watch?v=xm8o6kETml0
However, ContextCapture has direct export to DGN now. When exporting to DGN directly you can open your mesh model and it will not be opened read-only: https://www.youtube.com/watch?v=rNoVCMFYWTo
Hope this is helpful for your retouch workflow.
