when importing a mobile point cloud with its trajectory file, I keep getting the error "Only 0 valid points, can´t build POD (at least 16 required)".
Can you check my data to see what might be wrong?
I converted the point cloud from 1.4 to 1.2 using LAStools.
Thank you for your time
Sergio Wojtiuk
WHY inc
Channel Partner, Mexico
Hi Sergio,
We usually see this error when the timestamps don't match between the point cloud and the trajectory file or are not included in the point cloud. If they do match then I would advise that you put in an SR and we can then take a look at your data.
Hi, I would like to know if this problem solved or not, I need help for this matter
