Is there a way to force the result of the aerotriangulation that it is flat?
For a job I must generate a flat orthophoto generated from a film.
The film is about a concrete wall under water.
I've set the block type to "Vertical views only"
There are no servey points available.
After AT the result is not completely flat but curved.
Is there a way that the result can be drawn flat?
Werner
