I have 64 gb RAM and the spatial framework shows that the maximum RAM usage for a job 8.4GB but sill some of the tiles failed. it shows: Failed during Photos Pairwise matching. Here is the log:
1385.task_log_0.log
<?xml version="1.0" encoding="utf-8"?> <Job> <Version>1.3</Version> <JobName>job_20190118T071928_1_new project_B2R3P1_Tile_+025_+011</JobName> <TaskGraph> <JobInfo> <Descr/> <ProjectPath>E:\ContextCapture\Catalina_04_04_2018\new project\new project.ccm</ProjectPath> <ItemPath>Block_2\Reconstruction_3\Production_1\Tile_+025_+011</ItemPath> </JobInfo> <RunInfo> <SubmitHostName>DESKTOP-Q5I96RN</SubmitHostName> <SubmitUser>meida</SubmitUser> <SubmitTime>20190118T071928</SubmitTime> <Run> <RunHostName>DESKTOP-Q5I96RN</RunHostName> <RunUserName>meida</RunUserName> <StartTime>20190118T071931</StartTime> <EndTime>20190118T074423</EndTime> </Run> </RunInfo> <JobFeedback> <Version>1.3</Version> <Status>32</Status> <Percent>13</Percent> <Msg>Failed during Photos pairwise matching.</Msg> <PT/> <Tasks/> </JobFeedback> <Task> <Type>4</Type> <Workload>100</Workload> <ProjectPath>E:\ContextCapture\Catalina_04_04_2018\new project\new project.ccm</ProjectPath> <ItemPath>Block_2\Reconstruction_3\Production_1\Tile_+025_+011</ItemPath> <Run> <RunHostName>DESKTOP-Q5I96RN</RunHostName> <RunUserName>meida</RunUserName> <StartTime>20190118T071931</StartTime> <EndTime>20190118T074424</EndTime> </Run> <Id>0</Id> <TaskMsg> <Time>20190118T074423</Time> <Code>273956867</Code> <Msg>Failed during Photos pairwise matching.</Msg> </TaskMsg> <Percent>13</Percent> <Status>307</Status> <RetVal>273956867</RetVal> <DefinitionJson>false</DefinitionJson> </Task> </TaskGraph> </Job>
There is some cache which need to be deleted.
communities.bentley.com/.../482358
I have uninstalled CC and delete everything I can find in my C drive related to CC. Then reinstalled the CC.
could u be more specific on where are the cache?
Hi Meida,
Try to delete this file then resubmit it.
E:\ContextCapture\Catalina_04_04_2018\new project\Project files\Block_2\cache\A8\CC96241F2BBE26A3475BA89D0CDA6BF67516EB2BD8B4E8213C9B57DFF11EDE.a3d
Let me know if this works.
Bruneau
It worked, thanks. So why does this happened? And how should I prevent it from happening? If it happened later is there another way I can know which of these caches to delete without coming to technical support like this time?
Hi OtoHelp me pleaseI also have this error.I have 64 RAM and the tiles are divided into 40 GB.* zip file attachedThank!Production_2 - Tile_6.zip
