I have 64 gb RAM and the spatial framework shows that the maximum RAM usage for a job 8.4GB but sill some of the tiles failed. it shows: Failed during Photos Pairwise matching. Here is the log:
1385.task_log_0.log
<?xml version="1.0" encoding="utf-8"?> <Job> <Version>1.3</Version> <JobName>job_20190118T071928_1_new project_B2R3P1_Tile_+025_+011</JobName> <TaskGraph> <JobInfo> <Descr/> <ProjectPath>E:\ContextCapture\Catalina_04_04_2018\new project\new project.ccm</ProjectPath> <ItemPath>Block_2\Reconstruction_3\Production_1\Tile_+025_+011</ItemPath> </JobInfo> <RunInfo> <SubmitHostName>DESKTOP-Q5I96RN</SubmitHostName> <SubmitUser>meida</SubmitUser> <SubmitTime>20190118T071928</SubmitTime> <Run> <RunHostName>DESKTOP-Q5I96RN</RunHostName> <RunUserName>meida</RunUserName> <StartTime>20190118T071931</StartTime> <EndTime>20190118T074423</EndTime> </Run> </RunInfo> <JobFeedback> <Version>1.3</Version> <Status>32</Status> <Percent>13</Percent> <Msg>Failed during Photos pairwise matching.</Msg> <PT/> <Tasks/> </JobFeedback> <Task> <Type>4</Type> <Workload>100</Workload> <ProjectPath>E:\ContextCapture\Catalina_04_04_2018\new project\new project.ccm</ProjectPath> <ItemPath>Block_2\Reconstruction_3\Production_1\Tile_+025_+011</ItemPath> <Run> <RunHostName>DESKTOP-Q5I96RN</RunHostName> <RunUserName>meida</RunUserName> <StartTime>20190118T071931</StartTime> <EndTime>20190118T074424</EndTime> </Run> <Id>0</Id> <TaskMsg> <Time>20190118T074423</Time> <Code>273956867</Code> <Msg>Failed during Photos pairwise matching.</Msg> </TaskMsg> <Percent>13</Percent> <Status>307</Status> <RetVal>273956867</RetVal> <DefinitionJson>false</DefinitionJson> </Task> </TaskGraph> </Job>
Hi Elena,
Can you check the quality of this image to be sure it can be read?
D:/PSV/DRONE/20181120_TiNAO_Komunarka/C1201/C1201_Down/1341_2_0554_81525_Right.jpg
There may be some corruption in the pyramid folder of images. Try deleting the folder images from the block and resubmitting the task (C:\ContextCapture\Project\Project files\Block_2\images\..).
Hello Felix,
Thank you!
I checked the image you said and tried to delete the folder, but it did not help. Then I deleted the images that CC excluded after AT, they were orange in 3D view and the problem disappeared. In early versions of CC, deleting excluded images was not necessary?
It seems to me)
You do not have to delete the excluded images . It's block folder with pyramid images. If you view these images you may find that some are corrupt.
Hi Bruneau,
Please help me, I also have this errorA1-A5_B1 Model Vadj with kml - Tile_-050_+013.zip
Thank you very much
Freddy
How you identified that this which tile belongs to A8 this or other file..
