I have 64 gb RAM and the spatial framework shows that the maximum RAM usage for a job 8.4GB but sill some of the tiles failed. it shows: Failed during Photos Pairwise matching. Here is the log:
1385.task_log_0.log
<?xml version="1.0" encoding="utf-8"?> <Job> <Version>1.3</Version> <JobName>job_20190118T071928_1_new project_B2R3P1_Tile_+025_+011</JobName> <TaskGraph> <JobInfo> <Descr/> <ProjectPath>E:\ContextCapture\Catalina_04_04_2018\new project\new project.ccm</ProjectPath> <ItemPath>Block_2\Reconstruction_3\Production_1\Tile_+025_+011</ItemPath> </JobInfo> <RunInfo> <SubmitHostName>DESKTOP-Q5I96RN</SubmitHostName> <SubmitUser>meida</SubmitUser> <SubmitTime>20190118T071928</SubmitTime> <Run> <RunHostName>DESKTOP-Q5I96RN</RunHostName> <RunUserName>meida</RunUserName> <StartTime>20190118T071931</StartTime> <EndTime>20190118T074423</EndTime> </Run> </RunInfo> <JobFeedback> <Version>1.3</Version> <Status>32</Status> <Percent>13</Percent> <Msg>Failed during Photos pairwise matching.</Msg> <PT/> <Tasks/> </JobFeedback> <Task> <Type>4</Type> <Workload>100</Workload> <ProjectPath>E:\ContextCapture\Catalina_04_04_2018\new project\new project.ccm</ProjectPath> <ItemPath>Block_2\Reconstruction_3\Production_1\Tile_+025_+011</ItemPath> <Run> <RunHostName>DESKTOP-Q5I96RN</RunHostName> <RunUserName>meida</RunUserName> <StartTime>20190118T071931</StartTime> <EndTime>20190118T074424</EndTime> </Run> <Id>0</Id> <TaskMsg> <Time>20190118T074423</Time> <Code>273956867</Code> <Msg>Failed during Photos pairwise matching.</Msg> </TaskMsg> <Percent>13</Percent> <Status>307</Status> <RetVal>273956867</RetVal> <DefinitionJson>false</DefinitionJson> </Task> </TaskGraph> </Job>
Hi Surendar,
Problem solved. It caused by my harddisk was full.
However, the error message from CC engine is quite misleading.
Freddy
Regenerate/rebuild also the Windows 10 search index. Some of previous Windows versions before updates had issue of too large search index which wasted lot of hard disk space especially SSD.
Hi Bruneau!
How you identified cache file that belongs to this
A8/cache/CC96241F2BBE26A3475BA89D0CDA6BF67516EB2BD8B4E8213C9B57DFF11EDE
using the log file? Or can find the cache file using the tile number/tile name?how?
Please answer my doubts..
Thanks Bruneau.
