Hi.First of all, my available software is the following, so please feel free to move my question if it does not fit in Descartes topic:
-Microstation-PowerCivil-Map-Descartes (for Microstation)
Is there any possibility to generate a georeferenced raster from my CAD model? There are a number of ways and formats available if I want to attach a georeferenced file, but I have not yet found a solution for exporting these files.
The only solution I have succeeded with is exporting a PDF with georeferencing enabled.
Crossing my fingers and thanks in advance.
Regards,Thomas H. Stavik-KarlsenSenior Engineerhttp://www.Akersolutions.com
Hi Thomas,
You will need to use (in Descartes) the 'Merge' command in menu 'Deliver' and in the 'Output' choose desired format (GEOTIFF, tiff, itiff64...).
Hope this help!
Bruneau
Answer Verified By: Thomas Stavik-Karlsen
Thanks, Bruneau.
This seems to work exactly like I was hoping for. Now I just have to find the best settings :-)
