Hi!
I want to obtain 3D model from point cloud data, *las format. But some tiles is failed and and tiles that have been completed are not displayed in 3D view
Log file of failed tiles
<?xml version="1.0" encoding="utf-8"?> <Job> <Version>1.3</Version> <JobName>job_20190122T092442_05_Esssssss_B1R1P1_Tile_3</JobName> <TaskGraph> <JobInfo> <Descr/> <ProjectPath>C:/Esssssss\Esssssss.ccm</ProjectPath> <ItemPath>Block_1\Reconstruction_1\Production_1\Tile_3</ItemPath> </JobInfo> <RunInfo> <SubmitHostName>DESKTOP-N01NPNA</SubmitHostName> <SubmitUser>FTM-2</SubmitUser> <SubmitTime>20190122T092442</SubmitTime> <Run> <RunHostName>DESKTOP-N01NPNA</RunHostName> <RunUserName>FTM-2</RunUserName> <StartTime>20190122T123110</StartTime> <EndTime>20190122T123210</EndTime> </Run> </RunInfo> <JobFeedback> <Version>1.3</Version> <Status>32</Status> <Percent>32</Percent> <Msg>Failed during 3D mesh refinement.</Msg> <PT/> <Tasks/> </JobFeedback> <Task> <Type>4</Type> <Workload>100</Workload> <ProjectPath>C:/Esssssss\Esssssss.ccm</ProjectPath> <ItemPath>Block_1\Reconstruction_1\Production_1\Tile_3</ItemPath> <Run> <RunHostName>DESKTOP-N01NPNA</RunHostName> <RunUserName>FTM-2</RunUserName> <StartTime>20190122T123110</StartTime> <EndTime>20190122T123212</EndTime> </Run> <Id>0</Id> <TaskMsg> <Time>20190122T123210</Time> <Code>286584842</Code> <Msg>Failed during 3D mesh refinement.</Msg> </TaskMsg> <Percent>32</Percent> <Status>307</Status> <RetVal>286584842</RetVal> <DefinitionJson>false</DefinitionJson> </Task> </TaskGraph> </Job>
<?xml version="1.0" encoding="utf-8"?> <Job> <Version>1.3</Version> <JobName>job_20190122T092442_10_Esssssss_B1R1P1_Tile_5</JobName> <TaskGraph> <JobInfo> <Descr/> <ProjectPath>C:/Esssssss\Esssssss.ccm</ProjectPath> <ItemPath>Block_1\Reconstruction_1\Production_1\Tile_5</ItemPath> </JobInfo> <RunInfo> <SubmitHostName>DESKTOP-N01NPNA</SubmitHostName> <SubmitUser>FTM-2</SubmitUser> <SubmitTime>20190122T092442</SubmitTime> <Run> <RunHostName>DESKTOP-N01NPNA</RunHostName> <RunUserName>FTM-2</RunUserName> <StartTime>20190122T123604</StartTime> <EndTime>20190122T123700</EndTime> </Run> </RunInfo> <JobFeedback> <Version>1.3</Version> <Status>32</Status> <Percent>1</Percent> <Msg>Estimating normals for point clouds...</Msg> <PT/> <Tasks/> </JobFeedback> <Task> <Type>4</Type> <Workload>100</Workload> <ProjectPath>C:/Esssssss\Esssssss.ccm</ProjectPath> <ItemPath>Block_1\Reconstruction_1\Production_1\Tile_5</ItemPath> <Run> <RunHostName>DESKTOP-N01NPNA</RunHostName> <RunUserName>FTM-2</RunUserName> <StartTime>20190122T123604</StartTime> <EndTime>20190122T123700</EndTime> </Run> <Id>0</Id> <Percent>1</Percent> <Status>307</Status> <RetVal>-529697949</RetVal> <DefinitionJson>false</DefinitionJson> </Task> </TaskGraph> </Job>
Hi Elena,
Send us the logs file, right click on failed tiles then choose "Export log file for technical support".
Bruneau
Hi Bruneau,
Production_1 - Tile_5.zipProduction_1 - Tile_3.zip
Thank you!
Log file are showing that Vulkan is toggle "on" and there is only one graphic card (GTX 1050). In such case it is not recommended to use the Vulkan settings, we suggest you to toggle "off" the Vulkan setting then resubmit production.
Hello Bruneau,
Thanks! Now all the tiles are completed!
