In the past I could download the CC Viewer and install it locally on a number of my clients computers to view 3D models. Now under Connect services it seems that I have to connect to the hosted server and validate a license to run the viewer. Is this correct and if so why the change? How can I provide 3mx models to third party clients for viewing. I realize that I can publish web models but many of my clients do not have reliable internet access
Farouk Rohoman
They can register user for connection client even without SELECT/CSS. At least there is no more difference between CCviewer delivered with CC and seperate download.
Hi OtoThanks for the response. As far as I know an inter connection is still needed to use the viewer. A number of my clients in isolated communities in Northern Canada do not have internet connections and if they do, the connection is not reliable or very expensive as they use satellites phone technology for access. These clients use standalone software such as ESRI Arcexplorer, Adobe Reader, Autodesk TrueView etc. to view documents, CAD/GIS files without being connected to the Internet. They will question why the same is not true for 3D meshes from Context Capture. Other clients will find it inconvenient to maintain a Bentley user/login just to use the viewer. Bentley should consider all clients not just those who sit in offices in big cities with fingertip internet access.
Seems you have to use older version then. What does it show if not connected to internet or connection client is not installed?
It says that I am using a "trial' version which will expire in 7 days.
Try to do a "reserve license" in license manager at least for Bentley View it doesn't seem to ask to login after 7 days.
