I have been trying to get CC to run a production from 200 drone images and the production keeps saying it is pending instead of running. I have deleted all the pending files in the queue repeatedly and rerun production but the production remains as pending for several hours. What else can be done to produce the model I need?
Thank you,
Denise.
Hi Denise,
Do you see a message similar to this screen shot?
If so, you need to launch the ContextCapture Engine to process the items in the queue, otherwise they will just sit there in the queue waiting for you to start the engine.
Regards,Ron
Ron this is what I see whenever I run a production. The engine runs well, its just very slow.
There might be one file in the "Running" folder ,in the job queue, that is retaining your job to process. I suggest that you delete also the files that are contained in that folder and see if this help. Let me know.
When try again, after delete the previous file in the queue, check your recostruction settings, the screen shot you posted show 19000 jobs (tile).
Thanks Ron, that worked for me.
