I'm using version 11 of Lumen RT, I'm working on Microstation Connect update 11, when I send my scene to Lumen I'm getting the following message (attached Image), after clicking on accept several times opens Lumen but the scene goes wrong.With the previous version of Lumen everything worked without problems, can someone tell me how to correct or why this failure occurs?thank you in advance for your cooperation
Hi Carlos,
I don't know why this EON Assert occurs, but the message gives you two options. The OK option appears to be for the developers and allows helps them to debug the issue. The Cancel option disables further Asserts and lets the export proceed without further interruption.
I get that message occasionally ,but I click cancel and it usually exports successfully.
Regards,Ron
thank you very much for the response, forget to thank but I saw the answer and put it into practice with good results.
