Failed during 3D mesh simplification
I am getting this error from context capture. Does anyone know what I could do to fix it?
Please a service request (https://connect.bentley.com) and include a copy of the log file for the failed task. To create the log file right mouse click on the failed task and select "Create logfile for technical support".
10TelokBlangahFull_CC_RE - Model.zipHi, i am having the same issue as above. I have attached the log here
10TelokBlangahFull_S_RE - Model.zip One more file here
Hi Sallihin,
The log shows that you are using CCC Update 10. We suggest you strongly to upgrade to latest version of CC as this mighrt have been fixed in recent version.
Wow! I should try this! Can't believe everything was so easy
png to ico
