Hi all,
Is there a way to replace the cover images after 3D model has been generated? The reason I ask this question is I would like to replace the cover image with masking image. For example, I would like to highlight the crack in this model
by replacing the images with masking images (black and white) and and finally update and attaching new images on the following model.
Thank you for the help.
With Contextcapture it won't be easy as Contextcapture or Contextcapture editor doesn't have texture/material editing capabilities. What you could do is produce orthophoto and then edit and drape that on scalable mesh from TIN.
