How to import image location accuracy
Hi guys
I can see how to import the location and orentation data for each image, but I would like to know how to import or set the accuracy of the location data.
I'm importing images from the DJI Phantom 4 RTK and have accuracies for each photo. These values range from about 20mm to 3m depending on if it had RTK initialisation or not at the time.
Pix4D automatically reads this information from the images.
I am surveying with check points only, so the accuracy of the photos is very important.
As a side issue version 4.4.11.60 does not recognise the camera parameters for the 'undistorted' images from the DJI Phantom 4 RTK.
Cheers
Caleb
  • As a side issue version 4.4.11.60 does not recognise the camera parameters for the 'undistorted' images from the DJI Phantom 4 RTK
    What do you mean by this? Undistorted images are flat so there are no camera parameters anymore.
  • All DJI Phantoms have fisheye lenses, but since the Phantom 3 the images are corrected for this on the fly, so the images you download from the drone do not have the barrel distortion (ie horizons are straight). However with the Phantom 4 RTK it now give the option to have the photos with out this correction applied to improve the accuracy of the processing. The camera in the Phantom 4 RTK is identical to the Phantom 4 Pro, but in Pix4D they have different calibration parameters. The RTK camera (without 'distortion correction' turned on) is a fisheye lens, and the Phantom 4 Pro is a rectilinear lens. However, it you use the RTK with the 'distortion correction' turn on, then choosing the calibration file for the Phantom 4 Pro in Pix4D works just fine.
    I get what you mean about undistorted images not having camera parameters, but that just means they don't have real phyisical lens parameters, they can still have calculated/psuedo parameters, as they have for Phantom 3 and 4 cameras.
    I hope Bentley have added support for the Phantom 4 RTK camera to Context Capture update 12.
  • P4 doesn't have fisheye lens it has 94° FOV wide angle lens. I am not aware of any corrections applied by P4 for barrel distortion in firmware. Maybe you are confusing with rolling shutter eefeff? Yes Pix4D has rolling shutter adjustment but it doesn't actually give better results.
  • Hi Oto. I'm not an expert on the technical difference between fisheye and rectilinear. But this thread makes it clear that corrections are made onboard the drone to make images with nice straight lines https://forum.dji.com/thread-83571-1-1.html
    Have you used the Phantom 4 RTK?
    I can tell you as a fact that you have a choice in images it will output - With or without 'distortion correction'.
    When using 'with distortion correction' the camera lens parameters for the Phantom 4 Pro work. Pix4D classifies this as a 'rectilinear lens'. With this setting straight lines look nice and straight.
    When using 'without distortion correction' the camera lens parameters for the Phantom 4 RTK work.Pix4D classifies this as a 'fisheye lens'. With this setting straight lines look warped near the photo edges, just like the Phantom 2. Pix4D also classified the P2 lens as fisheye.
    I don't know if Pix4D is using the correct terminology or not, all I know is what works and what doesn't.
    Nothing to do with rolling shutter.
Reply
