Interesting paper in advancements for 3d reconstruction of interiors.
Panoramas, if equipped with the depth information,could enable
However, panoramic 3D reconstruction has been a challenge for Computer Vision due to the minimal parallax, which is important to reduce stitching artifacts but makes it difficult to utilize powerful multi-view reconstruction techniques. The lack of texture exacerbates the situations for indoor scenes. The reconstruction accuracy of single-view methods is still far below the production level and successful panoramic 3D reconstruction has been demonstrated only with the use of special hardware such as a depth camera.
This paper proposes a novel Structure from Motion(SfM) algorithm for indoor panoramic image streams ac-quired by standard smart phones or tablets. The key idea is the fusion of single-view and multi-view recon-struction techniques. In the past, 3D vision community has rarely seen such fusion, mainly because single view methods are too “rough” to be directly used with the multi-view techniques. We seek to utilize single-view techniques to effectively detect geometric re-lationships of lines (e.g., detecting 2D lines as coplanar in3D), which in turn yield precise geometric constraints to be used in multi-view 3D reconstruction.
https://arxiv.org/pdf/1612.01256.pdf
Hi Oto,
Here's very impressive demo of an experimental panorama viewer that uses depth maps to calculate stereoscopic images on-the-fly from monoscopic images.
https://webuser.hs-furtwangen.de/~dersch/PTViewer3djs/index.html
This is from Prof. Dr. Helmut Dersch, the original creator of the Panorama Tools suite.
You'll find documentation and desktop versions on his homepage.https://webuser.hs-furtwangen.de/~dersch/
Regards,Ron
Thanks. The idea is that aerotriangulation could be improved for interior capture as for smaller rooms it is not possible to do a correct capture and if reasonable model could be produced by typical 360degree captures then it would help. Bentley position is that panoramas are of no use because it looks great but no real measurements can be done but at the same time there is no real alternative for capturing interiors, hand held laser scanning is great but it produces heavy models.
