Production_1 - Tile_+017_+003_+000.zipProduction_1 - Tile_+009_+008_+001.zip
同一個區域
卻會跑失敗,我看兩份文件的差別
之前有用同範圍只是區域比較小一點,但是所失敗的範圍是不同
請問是哪邊有問題
是有百分比錯誤和其他的,原因是重疊率不夠嗎
The first production has failed due to a license activation failure. Please run the Activation Wizard to ensure that the license is correctly activated. I notice that you are using an older version of ContextCapture. We would recommend that you update to the latest version Update 11 (04.04.11.60). This version now includes Bentley CONNECT Licensing which only requires that you are logged in to the CONNECTION Client for your license to be activated. A license key is no longer required.
The computer that you are using is below the specification that we would recommend for ContextCapture. We would recommend 64GB of RAM whereas you only appear to have 8GB. We would also recommend the user of a better graphics card. Using a computer that is below recommended specification will likely lead to more problems occurring. Please see the link below for our hardware recommendations:
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/26310/what-are-the-minimum-recommended-system-requirements-for-contextcapture-contextcapture-center
