I am using Context Capture Center Edition. I have crated a stitched 3d model of a road. Now I am trying to export a 2D picture of the road surface so that I can highlight cracks and defects.
The problem I am facing is that I can't figure out how to export a quality 2D image of the bridge surface. The only thing that Context capture offers is a screenshot. I need a 2d image that keeps the resolution of the 3D simulation. Is there anything better that screenshots for exporting 2D images?
Thanks!
Hi Enoch,
You can try the ContextCapture Editor Merge tool, in which you can specify the output resolution of the 2D image to generate.
Here is some information on how to use it :
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/160985/contextcapture-editor-large-orthophoto
Mathieu
Thanks so much for the advice!Bellow is a screenshot of my Context Capture. I looked at all the options but I couldn't find this Editor Merge tool that you mentioned.Do you perhaps know where I could find this?
ContextCapture Editor is separate software bundled with ContextCapture Master for editing purpose.
Look the .exe in you install folder and you should be able to find it.
ContextCapture is a separate installation. You will need to go to the Fulfilment Center (https://connect.bentley.com) downloads section and search ContextCapture Editor. You will not require a separate license as this is included with ContextCapture.
