ContextCapture Control Point Validation
While using ContextCapture I'm attempting to set control points to geolocate the model that is being developed. In doing so, I've downloaded and selected the coordinate system I'd like to use (EPSG 2236). I've selected a total of three control points, and have selected a minimum of three photographs for each control point, and have entered the X and Y coordinates. Below is a screenshot of one of the points:
The problem I'm having is that none of the control points are valid; they only show up as "blue" meaning unknown accuracy and I cannot get them to show up as green. As a result, when I run the Aerotriangulation I'm unable to select the "Use Control points for adjustment" option under the Positioning/georeferencing tab:
Any help to figure this out would be much appreciated. Thank you,
Samuel Worthy
