When I ask ContextCapture to generate an OBJ and select ENU as the spatial reference system, what exactly does that mean? Is the Earth's curvature built into the model?
Is ENU a topocentric Cartesian coordinate system with no projection, or does it use a UTM projection?
Thank you,
Mike Longtin
There was some discussion of ENU regarding OBJ previously. https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/148702/contextcapture-e-n-u-projection/454637#454637
Basically ENU means Local tangent plane coordinates with east, north, up (ENU) coordinates in Cartesian coordinate system.
Thanks for confirming, Oto!
