What is difference between accurate and inaccurate position setting in aerotriangulation? Even if choosing accurate metadata it still uses compute method for position/rotation and produces wrong results even initial positions are correct. How accurate should be positions to count as accurate metadata?
Why even in accurate georeferencing the positions seems to be ignored? Seems the aerotriangulation is too relax and accurate metadata can be used even with consumer grade GNSS.
Hi Oto. What exactly do you mean? Where is the 'accurate metadata' option? In the 'positioning/georeferencing' section I choose to adjust and final positioning to the photo metadata. But in settings I cannot choose and estimation policy other than 'compute'. Thanks
