Please go to http://connect.bentley.com and submit a service request. You will need to include a log file from the failed task. A member of the technical support team will be able to assist.
Thanks for your help, but i have not permission to submit a service request. however i attached the logfile here. please help me to solve my problem if its possible.thank you...PART_13_1 - AT.zip
We note tat you are using an older version of ContextCapture. We would advise that you update to the latest version of ContextCapture Update 12 (04.04.12.347) and then resubmit the Aerotriangulation.
The current AT appears to have some corruption.
What is new in 04.04.12.347?
I see that rotation glitch is still there https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/153109/contextcapture-3d-viewer-rotation-glitch.
It is not fixed for more than a year and still counting. Development is so slow.
Change naming convention of images from D:/ to //D/ (in reference manager)
