We have a license Bentley Descartes for Microstation. It works on Microstation V8i but i realized that it don't work on Mirostation Connect Descartes, I just get a trail.
Should it be this way or is something wrong? I thought there are no support on Microstation V8i Descartes?
Regards Magnus
If you have installed the latest version of MicroStation and Descartes for MicroStation you should also have the latest version of the CONNECTION Client. Please ensure that you have successfully logged in to the CONNECTION Client so that the license is enabled. If you have done this and are still running in trial mode run the License tool to confirm the license status and your entitlement.
If you require further assistance you will need to create a service request. https://connect.bentley.com
Okey. I see that I have installed Bentley Descartes Coonect Edition, should that be correct or are there another Descartes for Microstation Connect?
My Connection client says that I have the latest versions.
If you had Bentley Descartes for MicroStation your installed upgrade must be to Bentley Descartes for MicroStation CONNECT. Bentley Descartes is a different product. See the link below for details of how to installed Descartes for MicroStation CONNECT:
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/32678/descartes-for-microstation-connect-edition-installation
Answer Verified By: Pascal Cloutier
