Hi folks!
I'm a new to the 3D Scan things, and hopefully you could suggest a proper working workflow for my current setup.I've got a Leica BLK 360, I am stitching the files with Ipad Pro (Autodesk Recap Mobile Pro) and Autodesk Recap Pro.
Now I need to transfer these results to Bentley Pod, because it's the only format that is compatible with siemens NX reference point cloud solution.
From Autodesk i can export to this formats:
-E57-PTS-RCP-RCS
and how could/should i transfer this to Bently .pod?
Thank youWarm regardsS.B. Arunprakash
Mobile: 8050007724
Very simple : you have to attach the e57 pointcloud using the attach pointcloud tool and MicroStation automaticaly convert it into POD. Only POD files can be attached to a DGN by MicroStation.
Philippe HALET
CEO at beCAD a Gold Channel Partner
