My system has 64gb of RAM. I set the target RAM usage to 32gb in the spatial framework, and I am still getting an insufficient memory error for 2 out of 22 tiles. What am I missing?
It may happen if some parts are in higher resolution then the adaptive tiling may not find optimal tiling.
Hi there, did you ever find a way to fix this problem please?
Not really. I believe there was an update since I posted the problem. I haven't messed with it much since then.
I have seen this error recently (since Update 15) under similar RAM conditions. My problem was not an error with RAM, but enough disk space on the drive where the production was running. I think I had ~50GB of space on the drive already, but I made more space and the problem went away.
