Does anyone have any information on how you go about linking up multiple computers within a network to process context capture models?
In order to use parallel computing with ContextCapture Desktop you must have the latest version (04.04.12.347) installed.To set up parallel computing you must do the following:Create a shared folder accessible from both computers. Read /Write permission must be enabled for all users.In here you can place a folder for the Job queue, a folder for the photos and a folder for the project. All of this information needs to be accessible from both computers using the exact same path information.In ContextCapture Settings on both computers configure the path to the Job Queue. This will be identical on both computers.
For ContextCapture Center the process is similar but you can have more than 2 Engines
I suppose the parallel computing requires two licenses then.
Yes that's correct.
