I am trying to convert an LAS file that I obtained from Maine's Lidar inventory into a point cloud so I can display it in the Microstation Connect edition. I have found the convert task, and connected to the LAS file, but keep getting a convert failed. I have tried other files, and changing the settings, but nothing works. Any suggestions?
Do you know which LAS version the file is in? See the following article:
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/realitymodelingwikitr/32592/unable-to-attach-las1-4-point-cloud-image
Also you could try free Bentley POD converter/creator.
