Hi, we have just purchased the product and we are trying to process or first project (122 images). It does the aerotriangulation just fine, but it takes way to long to process a 3D Mesh reconstruction (2 hours and counting, and we have 64 GB RAM computer). I am guessing there is a problem. I've tried to oppen the CC Settings to check wich engine is using, but the window pops out when I try to open it.
Does anybody has any insight in how to solve any of my problems? Thank you anyway.
And what graphics card you have?
The typical production speed is 20-30Gpixels per day.
ASUS R7 240
It may not be supported you have to check CC Settings and the benchmark score for this card. The score should be not less than 100 otherwise it will be slow. Also production speed partly depends from CPU cores and CPU speed also.
ok, thanks, I will try to find the recomended expecifications. My new problem is that I am not capable to open CC settings, as it collaps when I try to run it.
Seems to be similar issue try if it helps - https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/176907/error-opening-context-capture/512286#512286
