Hi all,
I cannot figure out how CC actually apply spatial reference systems. I try to be as clear as possible with this following example:
The workflow we then followed is:
Now... the model is pretty good, actually great to be used to show, but the altitudes are way off (like 30 meters, 30% off since the actual altitude is 105 meters and the model shows 130 to 135 meters) and GCPs positions are 50 cm off, which should not happen when you set ground control points to produce accurate scale, orientation and spatial position.
Could you please help us finding the issue? I was aware of a ContextCapture bug on the altitudes (which is crazy for a reality modeling software which costs a lot, the accuracy should be its job) but with so many settings for SRSs in the same production, maybe I'm a little lost.
Thanks.
Same question for me. It is very strange indeed as it pops only for a moment.
