merge procedure
Hi ,
Image a set of thousand of aerial imageries quite big tiffs, so how is the best procedure to make really great 3dmesh /3mx or 3sm
1. make many small meshes and somehow to merge to big one /CCeditor or something other?
2. from start to make only big one with all problems with memory and so on
3.any idea?
regards
Karol
  • Hi Bruneau,
    thanks , but as I said, I know this video, google is not very precise and correct in height ,
    I edited mesh on real survey data , and I thought if I repair mesh , the texture will be added from photos but it doesnt work , mesh left without texture, probably i will be make terrain plus ortho then export kmz and maybe then ,
    that was my question about procedure of repair which is succesed by somebody
    once more thanks for your response
    regards
    Karol
