Hi to all. First post here and it's about an offset in the altitude appearing post AT. The original metadata seems fine but after AT there's a shift of about 45m in the altitude and a substantial number of images can't be used which then results in the reconstruction failing. Has anyone seen anything like this before and could give some pointers or things to try?
Thanks Oto. Is Elipsoidal height the same as Orthometric? That's all I can see in the settings. I think in this case the UAV was set with distortion control to on (if that's what you mean by dewarped?)
There is a undocumented popup after photo import which allows to set the default GPS altitude reference.
Import photos and click modify in the status window:
