black block only in Orthophotos image generated by merge tool of Descartes
There is black block only in Orthophotos image generated by merge tool of Descartes
steps:
1:Start MicroStation CE update13 with Descartes
2:Attach 3mx model to the current dgn file.
3: User merge tool  in the Deliver section of reality modeling task
4: Define a block for the Orthophotos image area
5: Got tif file generated by merge tool of Descartes
6: There is black block only in the image file as attached video showed.
Could you help to provide some suggestion on what's wrong on it?
Thanks a lot
Jinlongtop123.tifclip123.tif
