I've been using Bentley programs for years, but lately always Select editions.
I have had Descartes loaded onto my machine, but it is Connect edition.
I'm sorry, but it is like some kind of bad joke. I'm really struggling to find many of the things I've always used.
Please don't ask me to use the search function - it is no better than the help in Select editions.
I'm trying to find the workspace settings so that I can set it to use two screens.
But also I need to access resources that will allow me to learn how to make the move from Select to Connect.
So that's 2 things - setting up operation with two screens, and tutorials to learn how to use connect.
You can bring V8i Task Theme in Descartes Connect, just done it! See image below.
For that you can follow instructions contained in the following link.
https://communities.bentley.com/products/microstation/w/microstation__wiki/24481/how-to-display-the-v8i-style-tasks-dialog-in-microstation-connect-edition-till-update-12
Bruneau
It is not v8i task theme it is to display tasks which is actually better approach than U13.
Thank you very much for your reply happy wheels !! It is very valuable.
Thanks.I'll try this
