GOOD DAY ALL
Please, can you help..
received this trajectory file data with our lidar dataset, but when we filter the time stamp (as being column1-208706.00806 etc as per the information received it gives us this error)
what am I going wrong or is the error in the trajectory information received
Hi, Did you manage to find a solution for this problem? I am using the DJI Zenmuse L1 data sets and haven't successfully imported anything yet.
Which Contextcapture version are you using?
Also verify that timestamps are not lost in input point cloud.
Hi Oto,
Currently running Update 18 - v10.18.0.270
How do I go about checking the timestamps?
Thanks mate
Cloudcompare?
Same, trying to import with no success.
Paul Najarro
Christopher B. Burke Engineering, Ltd.
