GOOD DAY ALL
Please, can you help..
received this trajectory file data with our lidar dataset, but when we filter the time stamp (as being column1-208706.00806 etc as per the information received it gives us this error)
what am I going wrong or is the error in the trajectory information received
Hi Paul, any later success on this? thanks
Do report with lasinfo of the cloud and post results.
Hi Oto, this is what i got using lasinfo in QGIS. It is the first time using Zenmuse L1 and CC so I am not sure if I am doing the whole process as it should be.
no still can't read trajectory file.
Paul Najarro
Christopher B. Burke Engineering, Ltd.
Hi All
I am having the same issues. I have received a las file and the corresponding trajectory files but get a mismatch error.
Been looking on the net to see how i can convert the SOW time to GPS time but not seen anything that works or really makes sense.
These are the time stamps i have on my .txt file and the Las file is saying it should be 1.35446e+09
Any idea what conversion method you should use or work flow. We have spoken to Bentley and DJI both say its the others problem.
Pete
