GOOD DAY ALL
Please, can you help..
received this trajectory file data with our lidar dataset, but when we filter the time stamp (as being column1-208706.00806 etc as per the information received it gives us this error)
what am I going wrong or is the error in the trajectory information received
Wasted effort. SOW is the same GPS time.
Problem is with Contextcapture strange way of interpreting data, it is Bentley way or no way.
Hi @ Peter Jackson. You can use LAStools: https://rapidlasso.com/lastools/
If you are struggling I can help in Terrasolid.
Regards,Jason.
Thanks Oto - how do you get around the mismatch issue ?
Thanks Jason
So Lastools should be able to solve the conversion / mismatch issue. ?
Yes, LAStools can convert your point between SOW and GPS and update the global encoding. If you need to change your trajectory I would do that in excel.
