In ContextCapture, while trying to produce an LAS point cloud, I get the error "failed: an error occurred while trying to write in a file" at 72%.
On the ContextCapture engine I see "Error: task failed (returned : 275091456).
I have tried re-submitting and restarting computer several times.
Can anyone help?
Thanks!
HI Chris,
You will need to create a log file for the failed task and send it to Bentley Technical support: communities.bentley.com/.../export-logfile-for-technical-support
Thanks Felix.
I think I may have figured it out.
I had about 30gb disk space. I freed up 10gb more and it processed.
The resulting LAS file was about 15gb.
If this was the problem... Perhaps a less cryptic error message from Bentley? How hard would it have been to just tell me I was out of disk space?
HI, thanks for the insight, This is useful.
