I'm using ContextCapture Master and while doing 3D MESH I usually leave the computer for several hours during the evening, so I'm not physically working on it.
As a result, when I come back in the morning, both the Master and the engine are closed.
The computer never goes to sleep or turns off the screen, so there is no reason for the computer shut down itself.
Is there any option to control the Bentley applications to work 24/7 while it is open?
Thanks for the answers!
you have MS_IDLETIMEOUT defined?
Hey Duncan,
I don't really know what does it mean. Can you explain?
In Microstation you can set variables to control the behaviour of the program and this is one that if set will cause Microstation to close if it isn't used for a set period. I suggest you talk to your system administrator or IT dept to find out how it has been set.
Is it possible to set it by myself?
Thank you! Have a good day.
