Hi,is there any chance to convert .3mx model to .imodel format?
My client wants me to use his .3mx models with iModel.js library. As I understand from iModel documentation, accepted extensions to upload are .bim and .imodel. I've tried to publish .3mx to .imodel using Bentley View CONNECT Edition already, but when I open a project in connect.bentley.com under ProjectWise tab, there is no model, just a skybox. Maybe there is a chance to convert .3mx to some different format first and then to .imodel? Thanks in advance.
Does iModel supports meshes with textures?
Hi Tomasz,
This works very nicely and sorry for just noticing your post.
You need to publish the iModel as a 3SM to Context Share and then reference into your model and then publish your iModel to iModelHub. Then you will see Reality Mesh will be streamed into your iModelOf course reach out if you have more questionsWill post a link to the step by step instructions and get them posted today
Are there some more step-by-step instructions available on the described workflow?
Dr. Arūnas UrbšysProjects Development Director, Ph. D.UAB "IN RE"Lukiškių str. 3, LT-01108 Vilnius, LITHUANIAPh.: +370-5-212-4660GSM: +370-655-55975arunas.urbsys(at)inre.lthttp://www.inre.lt | www.pcscad.lt
Hi Glen, where can we find the link to the step by step instructions ?
Any update to my question?
