I've been working with the ContextCapture software on a project to evaluate it's usefulness and potential applications I can use it for at a later stage. In generating models I have run into the following line in the CC Engine, which sounds like an error line to me, but it is not immediately obvious as one.
"Task was interrupted (job queue not reachable). Please check job queue access." See the attached screenshot for an example of it.
I have had this line pop up a few times, especially when running tiled production overnight with multiple other productions queued and pending while waiting for the current one to process.
Just over the weekend, I had a situation where the second production in a queue of six became stuck for 3 days and 6 hours, with none of the other four productions having a chance to process. Unfortunately I closed the CC Engine of that queue before I took a screenshot.
I am wondering:
Hopefully someone has seen this before, and I will update this thread with more information if it comes about. Thanks!
Hugh
Quick specs if useful:
CC - Update 14 - v4.4.14.73
My PC:
Production that got stuck
I am having this issue as well except mine is happening before Aerotriangulation even starts. Hoping for a fix in here.
Busca la ruta de tu archivo JobQueue.db, haz una copia de seguridad abre el archivo con un block de notas, luego elimina todo el contenido y guárdalo con el mismo nombre y extensión a mi me funciono
你好,有详细的步骤吗?
