adding tiles onto the project
hi,
I created a project with 25 tiles with 4095 photographs and 24 ground control points.
As a result of reconstruction, there was a problem with the number 001 + 003.
When I reconstructed the problem location using the same bounding box, the model improved, but when I replaced it with the corrupted file, it was lower than it should be.
what could be the problem?
thank you
Parents Reply Children
