Hi expert,
I've done made some productions in 3mx format, but my 3mx always failed, just one tile is failed.
why it happen?
How much RAM do you have and what is the target RAM set for this production?
Also check Event Viewer as such issues recently started to appear :
Error:
Unable to communicate with the display driver. The application must close. Error code: 2 (pid=15160 tid=2076 cctask.exe 64bit) Visit www.nvidia.com/.../support.html for more information.
Disabled pagefile and now at least get notification that memory was exhausted. Seems there is a memory leak as target RAM was set to 64GB with 128GB RAM available.
Windows successfully diagnosed a low virtual memory condition. The following programs consumed the most virtual memory: CCTask.exe (4824) consumed 125283782656 bytes, CCMaster.exe (17628) consumed 1781735424 bytes, and MsMpEng.exe (5200) consumed 325361664 bytes.
Seems it is caused by last drivers 441.87 and 441.66 not sure if latest 442.19 has also this issue.
Roll back to default driver from Windows Update resolved the issue for now.
