How can I edit a mesh generated with ContextCapture Mobile?
In what format is the mesh? Basically 3mx, 3sm, Cesium 3D tiles are not editable as it is multi-resolution LOD structure and to edit you need to regenerate all LODs.
Hi Oto,
As far as I know, when you use CC Mobile App the models just can be download in these formats:
So my questions is what would be the workflow if you need the retouch the model without having to reprocess the photos with CC Master?
Such workflow seems is not considered. For retouching OBJ or DGN is used.
Sorry. just forgot to thank you for your help.
You are welcome.
