How do I know I'm using a full license and not non-comercial?
Hi there
This has happened before and I don't know how to fix it. We have an ELS aggreement with Bentley for Context Capture, yet I process a job and after 5 days of processing I get orthomosaic images that are watermarked with non-commercial use.
How do I know when I open Context Capture that I have a full license? It is not obvious.
How do I restart the software with a full license to resubmit my ortho to produce it without the watermark? I don't want to start a new project and mark GCPs and then wait another 5 days for the reconstruction.
I have had this issue on several projects from time to time and it is very frustrating.
Thanks for your advice.
Parents Reply Children
  • That setting issue should be resolved very soon and you will again be able to use the "optimized computation" option. Normally if you have not go a license then When you start ContextCapture you will be warned as the product starts via the CONNECTION CLient. In addition to this you will either see a message in ContextCapture that it is in trial mode and that you have "x" number of days left. If more then 7 days have elapsed the software would not start. Additionally you can always check your license status in the Bentley Licensing Tool.applicatiion.
