This was done using a scanner that I believe is for producing Autodesk compatible format files.I want to import it into Microstation but I am told that to do this I must convert it to a compatible format. I am also told if this is done all the color data is lost. All I will get is a big white blob. So I have some questions on how to do this if it is possible.First is this true or is there a way to maintain the color data when exporting to a compatible format?Second, using the format suggested can I attach it to a DGN file to align my model to the information presented in the cloud?Third, it there a way to convert the point cloud into a 3d model?Fourth, would doing any of these operations work better if used in Descartes?Fifth, I am also told that what I want to do brings the program to a near stand still.Any other information or tutorials that would be helpful would be appreciated. If you can point me in the right direction I might be able to get where I would like to go.I am new to this so I apologize if some of my questions seem mundane. I think that Microstation should be able to do this but I am told it can't.
Open rcp in recap and export as a pts file . then attach the PTS of which microstation will automatically convert to a POD file. In recap you can also clip the file to smaller parts if needed.
