I am receiving this error message while trying to view my 3MX completed production in "3D View". When I open the production in ContextCapture Viewer, my surface shows up as one thin vertical line. I have checked the accuracy of my control points, my aerotriangulation looks good, and I have tried both WGS 84 and NAD 83 as my output SRS's, but keep receiving this message. Any thoughts? Thanks.
Which version you have?
I had this issue when tried to import photo positions from ECEF coordinate system.
I'm running Desktop edition Update 13- v4.4.13.514
my photo positions are straight from exif data on the Phantom 4 Pro V2
If you are just using WGS84 this may be the cause of your problem. Try using an SRS that uses numeric values rather than Longitude / Latitude (in degrees).
Answer Verified By: Jake B
Thanks Felix, this solved my issue.
