I just upgraded contextcapture (yesterday) from update 14 to update 15. I have a project running that I needed to modify the geometry (delete part of the mesh). So I generate DGN for modification in the production, modify the files in microstation update 13, try to import, CRASH. Program closed. no message, no nothing.
I tried to regenerate the model using contextcapture 15, regenerate the DGN, try importing back. Same result.
Now I'm trying to re-install update 14...
Not happy
Hi Jérémie I have the same problem, did you find a solution?
I reinstall update 14 then do eveything in it. I did not had time to find an other solution
Same problem. Retouching was hard enough, but now it doesn't work at all?! unbelievable
This is an issue that we are aware of and a resolution is in hand. In the meantime we would recommend that you try to produce in OBJ format rather than DGN for retouching
u can use OBJ format and 3Ds Max for retouching
