Hi Guys, I am inserting some GCP in context capture, however, all the GCPs are in Hong Kong 1980 grid coordinates system but there's no such system in the pre-assigned coordinate system in ContextCapture.
May I know how can I change the coordinate system from WGS84 to local coordinate system (HK1980 grid system)?
Thank you so much!
Guys, I want to use the EPSG-2326 Hong Kong 1980 Grid Coordinate system, but i couldn't find it TT
you can export one prj file from global mapper, or you can edit one maunally, and reimport it or paste it in the table below.
