Mobile LIDAR Trajectory File format
I am trying to enter what I believe to be the trajectory files to accompany the LAS files. CC will only accept txt or csv files. However the list of files I was provided by a surveyor has the fomat "log" at the end of it so it is not being recognized as a text file (I think).  Any way around this so CC will import it into as trajectorry file? see attached screenshot:
  • The report tells me the trajectory files are indeed SBET
    however, the SBET file I found appears to be in a "OUT" format??
  • Yes take a SBET and convert it using utility  I attached in other post. Do a search of sbet in communities. Also I have registered feature request to add sbet format to CC so please register also so Bentley consider to add it as only one user who request it may not be enough.
    In latest CC U15 at last it is now possible to use Python API so will later take a look if it is possible to add trajectory from SBET using API but not sure if API has such possibilty. But overall adding API also to desktop edition of CC is right move as it makes it more popular and also can be used in such cases of missing format support.
  • Contextcapture SDK doesn't allow custom trajectory to be imported only txt.
    class Trajectories
    Trajectories handler suited for importing point clouds from mobile scans.
    readFromFiles((list)file_path_array, (FileFormat)trajectory_file_format) → MasterKernelError
    Return MasterKernelError. Read trajectories from formatted text files.
    File format must be defined for the input files with fields ‘x’, ‘y’, ‘z’, and ‘time’
